Electric Bass Finish Help Needed! http://www-.luthiersforum.com/forum/viewtopic.php?f=10101&t=18418 |
Author: | Brad Way [ Sun Aug 17, 2008 9:21 am ] |
Post subject: | Electric Bass Finish Help Needed! |
I getting ready to finish a bass I have been working on and would like some help with finish type and schedule. The bass is a maple neck through design design with a figured maple top and an ash back. I would like to finish the bass with a translucent finish. It has been many years since I have messed with any finishes but based on my limited experience I have a few guidelines I will be starting with. I would prefer to use a waterbased finish since I don't like to dealing with chemicals (VOC's, etc). I would also prefer somethings that is more workable like Nitro. (ie layer coats together, rub out, rework, etc) I would also prefer something that cures quickly (days not weeks). So with this being said...what grain filler, what sealer, what finish, how many coats, cure time, etc.... Thanks! |
Author: | jmanter [ Sun Aug 17, 2008 9:22 am ] |
Post subject: | Re: Electric Bass Finish Help Needed! |
Tung oil or True-oil are both awesome on basses... |
Author: | Brad Way [ Sun Aug 17, 2008 9:28 am ] |
jmanter wrote: Tung oil or True-oil are both awesome on basses... True-oil? Tell me more..... Any pictures of either finish? How many coats? How do you deal with wood like ash (open pores) with an oil finish. |
Author: | Ziegenfuss [ Mon Aug 18, 2008 11:28 am ] |
Hey man, I have not yet tried the hand-rubbed oil finishes or french polish, but they do look good to me...If you remember when we were at Hesh's place looking at his guitars, I know he has hand rubbed at least one and you would be hard pressed to pick it out from the crowd... I have tried some other finishes, and have settled in on a low VOC automotive poly...It is not as bad as nitro, and it dries to sand and buff in 8-16 hours (obviously, it takes a great deal longer to completely finish, but it will not mark like nitro early in its life). It looks really good...(and I spray it out of a preval unit) Stephen |
Author: | Michael Dale Payne [ Mon Aug 18, 2008 12:45 pm ] |
Cures days not weeks? Well waterborne acrylic lacquer can be rubbed out in 7-10 days if curing conditions are right. French polish is a process where you both build and rub out as you go tru-oil needs some cure time but not as much as waterborne depending on application process. So you have several options but understand each has a distinct film appearance and attributes. don't expect nitro harness from a quick cure product. That is not to say inferior hardness just different type of hardness. Nitro is hard but has little elasticity as compared to French polished shellac or a true-oil finish. So you should play with a couple of the quick cure finish and see what best suites you. |
